Auto-up Windows
VRXblack
Auto-up Windows
Postby VRXblack » Tue Oct 08, 2019 8:22 am
Hey Guys
Had a look around and cant really find anything, but was wondering if there is an option to have auto up switches for the windows? I'm not overly fussed with the back but primarily for the front.
I know its not a huge issue to just hold up the switch to get them up but figured if it can do down automatically then going back up should be easy enough.
Cheers
Black 2010 VRX Lancer
Re: Auto-up Windows
Postby lancerdarryl » Tue Oct 08, 2019 10:20 am
I’m fairly sure you can fit a later switch panel that has the auto up/down and it works ok
VRXblack
Re: Auto-up Windows
Postby VRXblack » Tue Oct 08, 2019 1:24 pm
lancerdarryl wrote:I’m fairly sure you can fit a later switch panel that has the auto up/down and it works ok
Oh really? Sweet thanks for that Darryl ill have to have a look around. Do you happen to know what model introduced them?
Re: Auto-up Windows
Postby lancerdarryl » Tue Oct 08, 2019 3:29 pm
My Evo is a 2013 it has them so I'd look for a VRX or Ralliart or Evo.I don't know if the lower models this vintage had them.
Re: Auto-up Windows
Postby bumblebee » Tue Oct 08, 2019 5:46 pm
Be interesting to see if it works with the newer switch panel. There was talk of this here on the forum some time ago and apparently there was an extra few wires to make it work from memory.
I'm keen to see how this turns out
Re: Auto-up Windows
Postby Lancer1993 » Tue Oct 08, 2019 7:14 pm
@bumblebee - any tricks with changing a setting on the car like the auto locks? This sounds more like how the windows were programmed. I know for a fact the windows in the Pathfinder my parents used to own had windows that went up when you held the switch for like a second.
I was told (on my CJ) they didn't do it for safety, better to have one hand on the switch than the steering wheel to get the windows all the way up?
Re: Auto-up Windows
Postby bumblebee » Tue Oct 08, 2019 7:51 pm
I went hunting for a setting like this in the ETACS box sometime ago and I couldn't find anything.
I do know what your talking about though
On the early Toyota Prado you could wind the window all the way down and then hold the button in and wind it up and hold it in for a out 8 seconds and then it would do an auto wind like the driver side does
However
I'm yet to find a setting for this.
If you go google on this forum there was much talk about this topic
There was a thread where they looked at the wiring and found there was more wiring to be done and it was abandoned
However
I'm keen so see if the panel that Lancerdarryl was talking about work's
Re: Auto-up Windows
Postby bumblebee » Tue Oct 08, 2019 8:11 pm
I have just sent a few emails to a few folks who are more familiar with the ETACS box then I
See what we come up with
Re: Auto-up Windows
Postby lancerdarryl » Tue Oct 08, 2019 8:20 pm
I'll have a look on both my Cars this week and see if there is any difference between them.Evo has auto up and the VRX doesn't
Re: Auto-up Windows
Postby bumblebee » Tue Oct 08, 2019 8:32 pm
Mmm
Interesting
With a bit of luck the plugs should be the same
Re: Auto-up Windows
Postby Lancer1993 » Tue Oct 08, 2019 9:07 pm
If its just a different switch then easy fix assuming you can find one at the wreckers and the CJ has any extra wiring needed.
Re: Auto-up Windows
Postby bumblebee » Thu Oct 10, 2019 4:42 pm
I got an email back about this
I need to test this
Hopefully inwill get time tonight
There is an option in the ETACS box for windows , I'm not sure ifnit is exactly what we were looking for
However
It's a step in the right direction
I will keep you posted
Re: Auto-up Windows
Postby bumblebee » Thu Oct 10, 2019 5:24 pm
http://mmc-autoelectric.org.ua/outlande ... ock-unlock
Just tried this
Unfortunately it didn't work
adamhumphrey
Re: Auto-up Windows
Postby adamhumphrey » Fri Oct 11, 2019 8:39 am
I went looking at this a while back for my wife's lancer. I think it's a totally different window regulator and switch. I think it also has to be changed to a different type of power windows in the etacs also.
MY11 Evo X MR (2011-Current)
MY20 Asx GSR (2023-Current)
Re: Auto-up Windows
Postby bumblebee » Sun Oct 13, 2019 9:46 pm
This is for a left hand drive outlander
AU $58.45 | WINSGO Car Window Closer Closing & Open Power One by One For Mitsubishi Outlander 2014-2018 Left hand drive
https://s.click.aliexpress.com/e/drM7FLkU
All we need now is one for a right hand drive lancer and we are cooking with gas
Return to “Interior”
